vnckramer
Jan 26, 2017Aspirant
WNDR3300v1 - Router not working
Our wireless connection went out, so I made sure everything was connected and restarted the router. This did not fix the connection. Then I check with our provider to see if our Internet connection w...
- Jan 30, 2017
It seems that you need a new router.
wcalifas831
Jan 26, 2017Prodigy
Try resetting your router and see if that helps. Also, you can try a different power adapter to see if that might be the culprit making your router unstable. Let us know what happens.
