Viking55
Feb 15, 2016Aspirant
WNDR3400v3 connects 5G and ethernet but not using 2.4G
I have an WNDR3400v3 N600 Wireless Dual Band Router which will no longer connect in the 2.4G band if security is turned on. The 5G band and all ethernet ports work fine. As I have 2 other 2.4G ac...
Retired_Member
Feb 15, 2016Have you reset it to defaults?
- wcalifas831Feb 15, 2016Prodigy
After firmware updates it's good to reset to defaults and do your settings over.
- Viking55Feb 16, 2016Aspirant
I'll give the reset to defaults a try, but the reason why I did the firmware update was because the 2.4G signal would not allow users to stay connected. The entire setup worked fine for close to 3 months with no changes made during that period.
- Retired_MemberFeb 16, 2016
And your point is? There are only several things you can do, If it worked once, then it's not likely a user setting will correct it.
1) reset it
2) reset it to defaults
3) change FW ( Up or Down ) and still Reset it to defaults
4) do nothing and replace it.
Good Luck!
