Viking55
Feb 15, 2016Aspirant
WNDR3400v3 connects 5G and ethernet but not using 2.4G
I have an WNDR3400v3 N600 Wireless Dual Band Router which will no longer connect in the 2.4G band if security is turned on. The 5G band and all ethernet ports work fine. As I have 2 other 2.4G ac...
Retired_Member
Feb 15, 2016Have you reset it to defaults?
wcalifas831
Feb 15, 2016Prodigy
After firmware updates it's good to reset to defaults and do your settings over.
