Viking55
Feb 15, 2016Aspirant
WNDR3400v3 connects 5G and ethernet but not using 2.4G
I have an WNDR3400v3 N600 Wireless Dual Band Router which will no longer connect in the 2.4G band if security is turned on. The 5G band and all ethernet ports work fine. As I have 2 other 2.4G ac...
Vellu
Jun 03, 2016Aspirant
It seems that I have exactly the same problem on another product (DGND3700). 5G band and ethernet works ok, but 2.4G band does not work. It works immediately after restart, but after a day or so, it stops working. The SSID is broadcasted and all the devices can attempt to connect, but the connection is dropped in practise immediately and the device just tries again.
I did reset to factory defaults less than 2 days ago, and now the problem appeared again. I bought DGND3700 early 2012, so I fear that it's time for a new ADSL router for me. If it had been 5G band that was not working, it wouldn't have been so bad, since most devices only use 2.4G band.
If you have any other hints on such problem (how to avoid it), it would be really useful and appreciated.
- VelluJun 08, 2016Aspirant
1) Yes, quite a few times, usually using the power switch, sometimes unplugging the power cord. I didn't get the original access point to work with reset only. Another access point seemed to work for a short while, but stopped working quite soon.
2) Yes, but only once. Immediately afterwards the original access point worked (or seemed to) for a while, but stopped working afterwards. I cannot be absolutely sure if the 2.4G access points really worked, I relied on the notification of the tablets (e.g. connected, no internet). And when the connection to internet was lost, it was too late to ensure.
3) I already have the latest firmware, so I cannot upgrade it.
4) I have another ADSL router in use at the moment, but it has different GUI and features (and problems), so having the original NETGEAR back would be nice... I will surely try it later again when I have the time.
Another symptom that I forgot to mention was that even though it showed that ADSL was connected, and I was able to access the GUI, all the computers in the network reported that they lost access to internet. Intranet was working, and GUI showed 20M+ DL and 1M+ UL speed towards ISP, there was no connection to internet from any device connected to ADSL router. After restart the connection to internet was resumed. It started to happen more and more often and it continued to happen after reset to defaults as well.
I had no USB devices connected there, only 4x eth cables (printer, NAS,8 port switch, computer). I also tried with only 1 computer connected via ethernet (+ the some devices using wifi on 5G band).
