bkeguy
May 06, 2017Aspirant
WNDR4300V2 slow in bridge mode with VDSL?
I've had a number of WNDR type routers (3400, 3400V4 and now 4300V2) and have worked well with my Cable modem (30M Down/5M Up). Recently I've switched to DSL and have upgrade connectivity to 50M D...
- May 06, 2017
the 30-30-30 reset
William10a
May 06, 2017Master
bkeguy wrote:I've had a number of WNDR type routers (3400, 3400V4 and now 4300V2) and have worked well with my Cable modem (30M Down/5M Up).
Recently I've switched to DSL and have upgrade connectivity to 50M Down/10M Up. When connected with both ISP provided Modem/router or a Smart RG 505 Modem/router I've been easily able to obtain these speeds with both WiFi and wired connections to the router. All works normally as expected.
I want to use my Netgear routers as my DHCP/Gateway and have configured the modem in Bridge mode. I let the router handle the PPPoE login and things seem to work fine EXCEPT speed drops to max 27-28M Down/ 10M Up (both wired and wireless). I've been pulling my hair out over this. MTU is set correctly (checked with Ping and verified with ISP). NAT/Firewall turned off on bridge. I've even tried both modems with almost exactly the same results.
Thinking it was a problem between the modem and router negotiating bridge setup I've set the modem up as the gateway and setup a DMZ host to point to the Netgear router (and my LAN behind it). Router is still DHCP server for my LAN and the router has a static "WAN" address on the same subnet as the LAN on the modem. Everything works great and I can login and verify both pieces of hardware. No double NAT issues and UPnP works fine. AGAIN the speed drops to 27-29Mbps. Too slow.
I have also taken an old TPLink router and replaced my Netgear router as the Gateway/DHCP server/router and speeds are back up to 50M Down/ 10M Up in both bridge mode and as the DMZ target. So this really seems to point to the Netgear modem as the bottle neck.
Any advice? I searched a bit and found a few similar posts but no resolution. Most suggestions were wrt MTU (which I've played with and verified with the other modem/router) or using it as a DMZ target which doesn't seem to increase my speed.
Am I hitting the limit of the WNDR4300? It is a relatively recent router (only a couple of years old) so I expect it could handle 50Mbps??
Any help or advice is greatly appreciated. Thanks in advance.
Yes i should be able to pass the 50mb without a problem on its 1gb ports one question has this been used with another network setup you may have to reset the router so it can learn about the new imodem and internet set up.
I guess that you have the users manual if not here is a link for it http://www.downloads.netgear.com/files/GDC/WNDR4300v2/WNDR4300v2_UM_23dec2014.pdf
