bkeguy
May 06, 2017Aspirant
WNDR4300V2 slow in bridge mode with VDSL?
I've had a number of WNDR type routers (3400, 3400V4 and now 4300V2) and have worked well with my Cable modem (30M Down/5M Up). Recently I've switched to DSL and have upgrade connectivity to 50M D...
- May 06, 2017
the 30-30-30 reset
William10a
May 06, 2017Master
the 30-30-30 reset
bkeguy
May 07, 2017Aspirant
Hi William10a
Well, I'm am very embarssed to say the 30-30-30 reset seemed to have flushed the settings and solved the issue.
Now I get my full DSL speed on my main router which is inside the modems DMZ zone. Works great.
I'm a little confused why the modem carried the cable modem settings over to the PPPoE in the original setup but I'm sure if I go back to bridge mode it will be fine as well.
For now. All is good. Thanks for the (obvious) suggestion which solved my issue.
Unfortunately I have to re enter my IP tables and all other user settings (if I can remember them).
(As an asside, is there an easy way to extract the routing table from the modem? I've telneted to my router and looked around but have been unable to find where BusyBox holds the routing table or how I can add it to the NVRAM?)
Thanks again.
- William10aMay 07, 2017Master
the old setting you had in the router are gone the 30-30-30 reset clears every thing
It may be in the config of the router part of he modem/router from your isp if you do a search on the make and model of modem/router should find a users manual on it.
