meik520
Nov 18, 2015Aspirant
WNR2200 - Vulnerability ID: NON-2015-0211
I got the warning Non-2015-0211 from my Avast scanner.
Searching for that I found this message: WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2200 with Firmware V1.0.2.24
Maintenance/Router Upgrade say No New Firmware Version Available.
I need a new firmware...
Best regards, Eugene.
Per our engineers, there will be no firmware updates on EOL products.
For all other products, our team is still investigating this matter.
Also, kindly make sure that you have followed the suggested solution by Avast.
Check for Alert messages stated on your Avast software. You may see this by clicking on the "Details" link.
After selecting it, scroll down and look for the "Alert messages."
- ElaineMNETGEAR Employee Retired
Let me inquire this to our engineering team.
I shall give you an update as soon as I have an answer.
Thank you!
- walter1337Initiate
i have the same problem with my Netgear router. I hope there will be a update son.
- alvinshookduffInitiate
yes i have thesame vulnerability.
Hello,
Our engineers are investigating on this reported issue.
Kindly make sure your devices are registered.
Once done, install teamviewer and let me know your contact details together with the preferred date and time when should we reach you to troubleshoot further on this.
Thank you!
My problem is now fixed, after the update to firmware V1.0.1.96
Thank you for the update walter1337
FW ver. 1.0.1.96 has fixed SOAP issue
While for users who have the latest FW ver 1.0.2.24 (for Russia and China only), we are still investigating on this.
For those users who are affected, kindly see the instructions that I have asked.
Thank you!
I have this same vulunerability and haven't received any responses about my issue. I just wanted to see if there were any updates to a fix for this problem. My firmware verison is V1.1.2.12.
Thanks!
- WildBillyAspirant
Any firmware updates for the WNR1000V2 to fix this SOAP vulnerability yet?
- Uriel23Aspirant
I have the same vunerability (as reported by Avast) on my JWNR2000v2. I updated the firmware to V1.0.0.11 but the vunerability remains; is there going to be any fix? Otherwise I have to buy a new router.
Furthermore, Avast says that my router is infected and my DNS had been changed - which is strange, because I switched them to manual (8.8.8.8) and dynDNS is off...
- PzooksAspirant
I have an R6100 with the same problems and warnings.
Are there any updates available for me??
I am still experiencing this issue with my router (Model WNR2000v3). I still haven't heard anything about a fix and I am growing frustrated with this. It was fine for a full two weeks before I started to get the same message again and I would like for someone to help me with this. I may just wind up getting a brand new router if I don't get a response about this. This is very frustrating.
- PzooksAspirant
Thanks Elaine. Looks like I have to download and install manually. The automatic updater doesn't see the most current firmware version.
I'll let you know how things work out. :)
