Jazzsterre
Mar 12, 2016Aspirant
WNR3500 keeps dropping the connection
Every 4 or 5 days my WNR3500L drops the internet connection and the wifi-connections.
I run with firmware V1.2.2.48_35.0.55 (the latest).
When I switch the power off and on again the router works again.
Can anybody give me some advice?
Hi, it helped to downgrade the firmware version, as described above.
I swithed off the settings to install the latest firmware.
- storm1985Prodigy
is the issue both wired and wireless?
if wireless only - change the wireless channel - use NETGEAR Desktop Genie > WiFi Connect > Wifi Analytics
it will give u some recomended channel under Channel Interference tab
- JazzsterreAspirant
It is both wired and wireless..
- ElaineMNETGEAR Employee Retired
If you bypass the router, will you get a stable connection directly to the modem?
By the way, who is your ISP?
