shayne100
Apr 16, 2021Aspirant
1 more hour and my last ever netgear purchase will be returned for a refund
Netgear Nighthawk R6260
I wasted several hours trying to set up this router yesterday before calling my providers technical support team who also wasted a couple of hours trying to work out why it will not connect . And today i've wasted another 4 hours .
My computer can find the router and so can my ipad but the router cannot find internet despite being plugged into British Telecom's home fibre network which is basically secured using an email address and password , is that ppeo or something i dont know because i speak english not dweebgeek . Regardless i'm getting nowhere .
Plug the ethernet cable into your modem - whats a modem if not a router - tech support says no you never plug a router into a router - ok so i plug the ethernet into the wall socket and nighthawk - now the set up wizard says cable not connected - so start again unlpug this and plug it into that any which way it can possibly fit - and repeat several hundred times - and fail . I forgot to mention httprouter login and 192.blahblahblah
So i'm asking here when i'm already at the end of my tether shall i send this back before i stamp on it or is there a secret somebody might share that makes it useable ?
- thehypnootoadLuminaryYour router needs a modem to connect to from the bt socket (rj11).Then ethernet from the modem to your router and then a password and username. Netgear supply router or all in one router/modem combo yours is just a router. You can pick up a huawei hg612 modem of ebay or amazon for 10-20 quid.
- shayne100Aspirant
So i need 2 routers to replace the free one from my internet provider because netgear doesn't sell routers .
Thank you hypnootoad at least i know now i wasted about £50 and 10 hours of my life because netgear are not fit for purpose .
Disgraceful . Junk . Rip Off . DO NOT BUY NETGEAR !
- microchip8Master
You seem to be confused. NETGEAR sells routers, modems and router/modem combos. If you have a pure router, it needs a modem to connect to. If you have a router/modem combo, you can connect it directly to the plug. Your R6260 is a pure router which needs a modem to connect to. You can use the modem or gateway of your ISP (if it's a gateway, set it to bridge mode) or you can buy an ISP approved modem from NETGEAR or other vendor at your choosing.
BT usually provides some sort of box that connects you to the Internet. You may need to plug into that.
As you have been told, that is a router. On its own its is useless.
Unfortunately, "home fibre network" doesn't tell us what sort of Internet you have.There's fibre somewhere in every "home network" connection. And BT uses the fibre term to try to persuade customers that they are getting something special. They aren't.
The most common technologies are DSL and Full Fibre, also known as or fibre to the premises or FTTP.
BT's DSL customers usually get a HomeHub, a pile of rubbish that prevents you from using it on "modem only" mode.
BT has very few people on FTTP at the moment.
You'll have to tell people what sort of broadband you are on for better advice.
One guide to the technology you are on is the speed that BT promises to deliver. The top speed for DSL is usually around 70 Mbps. FTTP could be a lot faster, up to 900Mbps.
If you haven't been there already, BT's user forum, its equivalent of this place, is a good place to start.
Welcome to BT’s official support community.
There are many more BT users there than you will find here, and plenty of them use Netgear kit. Try a search there for your device, or any Netgear router. The settings will be the same.
