PH123's avatar
PH123
AC1900 C7000v2 Firmware Update
Bought the AC1900 WiFi Cable Moden Router Model C7000v2 in Dec 2020 but just hooked it up this week (3/25/21).  Upon setup, received "Firmware Out of Date" message.  The Nighthawk app/Routerlogin.net brings me to a NETGEAR genie page but there is not an option to update the firmware. Of course, the 90 day complimentary warranty is expired, although I haven't used the piece of equiment yet, so when I called for help the support person just wanted to sell me an extended warrenty.  How nice.
Am I able to update this firmware? ISP provider is Spectrum.
  • > [...] Upon setup, received "Firmware Out of Date" message. [...]
       "received" from _what_?  (Trust no one, I always say.)
    > [...] Am I able to update this firmware? [...]
       On a C7000v2?  No.
          https://kb.netgear.com/000036375
       Is there some actual problem, or only the useless/misleading message?
    • PH123's avatar
      PH123
      The message is in the Nighthawk App which I was using to set up the router/modem.  I am not able to move beyond this "Out of Date"message in the App.  I'm wondering if this firmware issue is why my printer is unable to connect to the router - ?
      • > The message is in the Nighthawk App which I was using to set up the
        > router/modem. [...]
           More fine Netgear software.  I'd use a web browser, and forget the
        app.
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual (at least).  Read.  Look for
        "Log In to the Modem Router".
        > [...] I'm wondering if this firmware issue is why my printer is unable
           I doubt it, but what do I know?  I don't even know what your "my
        printer" is (maker, model number), or if it ever worked in any other
        environment.  Most printer problems are not the fault of the router, but
        many things are possible.
           "unable" is not a useful problem description.  It does not say what
        you did.  It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
           Generally, I'd fetch the documentation for the printer, and do what
        it says.
  • michaelkenward's avatar
    michaelkenward
    There's a bug in the Nighthawk app that throws up this message.
    You have no control over the firmware on your cable modem/router so it means nothing. It is just annoying and gets in the way.
    Netgear knows about this. But don't hold your breath waiting for an update.
    Nighthawk app same "firmware not updated" when it ... - NETGEAR Communities
    You might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Cable Modems & Routers
    For the apps try the section linked above.
    • antinode's avatar
      antinode
      Guru
      > No. [...]
         Thanks for repeating the information in the first reply.  Are you
      trying out for the role of sidekick to Lady Redundant Woman?
