viall26's avatar
viall26
Adding a GS108 switch to Nighthawk R7800
I have a new home with a smart panel that has all rooms wired for cat6. I have tried adding the GS108 to my router and lose my wireless network. When I unplug the switch and restart the modem and router my wireless network is back. What am I doing wrong?
  • Does this problem happen when you plug in the Ethernet switch with nothing connected to the switch? If just plugging in the switch causes the problem, I would replace the switch. If things are normal with nothing connected to the switch, try adding one Ethernet device at a time. Power each device off/on before adding it.
  • > I have a new home with a smart panel that has all rooms wired for
    > cat6. [...]
       Define "smart panel".  Is it any more than a patch panel?  Are
    devices already connected to the room ends of these cables?
    > [...] I have tried adding the GS108 to my router [...]
       "adding" how, exactly?  What, exactly, are you connecting to what,
    exactly?  Hint: If a device has multiple Ethernet ports, then "connected
    to device" is not enough detail.
    > [...] and lose my wireless network.
       What do the LED indicators on these devices indicate?
       Visit http://netgear.com/support , put in your model number(s), and
    look for Documentation.  Get the User Manual(s).  Read.  Look for the
    LED indicator descriptions.
    > [...] What am I doing wrong?
       Need to know what you're doing, first.
       You should be able to connect any one Ethernet port on the switch to
    any one LAN Ethernet port on the router.  Other devices should be
    connected to open Ethernet ports on the switch or open LAN Ethernet
    ports on the router.
       A plain GS108 is an unmanaged switch, and should be too stupid to
    cause any serious trouble all by itself.
    • viall26's avatar
      viall26
      Each room is wired for cable and two cat6 ports. All that wiring feeds into the panel. I also have my direct tv and Clare home solutions coming into the panel. Inside the panel I have my Arris modem and nighthawk router. I have my wireless network working correctly. I purchased 1ft cat6 lines To hardwire a couple devices into the router. My kids computer is plugged into the port in his room and a 1 ft cat6 from its designated spot in the panel to the router. Same with the living room TV. My goal is to add all the rooms to the available ports in the gs108. I plugged the switch into port one of the router and port one of the switch and proceeded to add the remaining cat6 lines from the ports in the panel to the switch. The lights on the switch that are active are green. The lights on the router corresponding to the ports are white. The light corresponding to the wireless signal is Amber. I have also tried plugging the switch into port one of the router and port 8 of the switch. Ports in rooms not receiving signal and no wireless signal. Unplug switch and put all connections back the way they were originally and restart modem and router and all signals return to room ports and wireless.
      • myersw's avatar
        myersw
        Master
        What firmware version are you running? Number not something like latest.
        Can we net this out to if you plug into the switch from the router you lose wireless or am I missing something? Have seen a few reports of losing wireless when Ethernet device is used. Reason for firmware version.
