virtualuk
Nov 15, 2016Tutor
Beware, Plex only runs off of USB and not NAS on the R9000
If you're thinking of getting the R9000 so you can get a fast WIFI router/switch (which it is) **and** retire your PC that's currently running Plex think again unless you have a small media library. ...
- Nov 15, 2016
Where can you buy a 16TB NAS running Plex, new for less than $500?
Your response adds no value to this thread. One of the key features, which was co-marketed with the Plex team was it's ability to replace your standalone PC Plex server. People should be aware of this "BEFORE THEY BUY", especially if it's a feature that would otherwise expected to be present as is the case with all standard copies of Plex running on said PC Plex server.
Retired_Member
Nov 15, 2016For less than $500 you could by a NAS capable of running Plex
