virtualuk
Nov 15, 2016Tutor
Beware, Plex only runs off of USB and not NAS on the R9000
If you're thinking of getting the R9000 so you can get a fast WIFI router/switch (which it is) **and** retire your PC that's currently running Plex think again unless you have a small media library. ...
- Nov 15, 2016
Where can you buy a 16TB NAS running Plex, new for less than $500?
Your response adds no value to this thread. One of the key features, which was co-marketed with the Plex team was it's ability to replace your standalone PC Plex server. People should be aware of this "BEFORE THEY BUY", especially if it's a feature that would otherwise expected to be present as is the case with all standard copies of Plex running on said PC Plex server.
Retired_Member
Nov 15, 2016For less than $500 you could by a NAS capable of running Plex
virtualuk
Nov 15, 2016Tutor
- mondenathNov 16, 2016Prodigy
I dont buy it. if one can buy a router which support plex being one of prime reason doesnt mean that he can get plex enabled NAS along with router.
This was prime marketed for Plex build it otherwise a media server which is could connected. Just like full fledged media server cloud enabled.
There is no point having a 10gb port in a router where the available port is only 6 each 1gb and even the ad tech of 4gb gives you effective 1-2gb for a most idle scenario of 5% efficiency.
It will not even consume 60-70%. only a plex server when used online can serve the purpose.
- Retired_MemberNov 16, 2016
The R9000 is Utterly Useless as tits on a bull. This whole concept of USB BS continues to thrive only because the number of gullible customers is endless.
Take away plex and the 60ghz what's left?
- raven_auNov 20, 2016Virtuoso
virtualuk wrote:Where can you buy a 16TB NAS running Plex, new for less than $500?
Strangely enough my reading of the marketing info. lead me to think that the Plex library would need to be on locally attached USB storage.
I haven't seen 16TB external USB drives anywhere so that doesn't make sense and you still need to buy the external USB drives for this so the cost is higher than suggested.
Never the less I like the idea quite a bit but thinking about it there are a number of hurdles to overcome to actualy do this even to use the router instead of an existing NAS.
Typically there will be other related services running on such a NAS and AFAICS there's no way those other services could be run adeauately on the router so the NAS would need to be used for that.
Then there's keeping the USB drives (plural since there likley too small for a media library) up to date since the library would need to be duplicated elsewhere for backup purposes. And there are only two USB ports so if your media library out grows two external USB drives your stuck.
And then there's the transcoding that unfortunately needs to be done by Plex all too often.
I don't know if the router will be better at this than a NAS but given that transcoding a 1080p video on the 2.0Ghz quad-core NAS is barely doable and sometimes in just not enough makes me wonder.....
Ian
- virtualukNov 25, 2016Tutor
My media collection is 11TB (16TB RAID 5 NAS), a USB stick/drive isn't an option. I'm surprised though that given the resources and capabilities of the router that mounting a NAS drive wasn't made an option, seems like a fairly straightforward proposition.
The horsepower of the Netgear router is more than I have on my paltry dual core mini PC that is currently running Plex, I'm not too concerned about transcoding either.
If they hadn't made such a big song and dance about it and just added it in there that would have been one thing, but to go on a big PR campaign about it and then to be limited to USB drives for media just seems a bit short sighted given that most movie buff collections will far exceed most USB drive capacities.
- raven_auNov 27, 2016Virtuoso
virtualuk wrote:My media collection is 11TB (16TB RAID 5 NAS), a USB stick/drive isn't an option. I'm surprised though that given the resources and capabilities of the router that mounting a NAS drive wasn't made an option, seems like a fairly straightforward proposition.
Yes, my collection is not nearly so large.
But constantly buying larger usb drives so I could back it up got annoying pretty fast.
And if I were to get an R9000 and use Plex this restriction just brings that problem right back again.
I don't think it's sensible to put mounting of volumes in Plex, it's not a Plex responsibility.
Putting that elsewhere and making sure Plex can use the mounts is really a must though.
Ian
