KuTcH's avatar
KuTcH
Bought nighthawk x10 and t9e when gaming i still get ping spikes when gaming
I tried everything from metered connections to cmd setting to even wall outlets for wired. I honestly don't know what to do here. When i play video games ill be fine and then my ping will shoot up to 300 for 1-5 seconds then go back to normal it it happens randomly and often some times i see it shoot up too 500+. I can't run a wire across my house but if theres a fix i would like to know
  • Hi KuTcH,
    Just to isolate if it is just wireless connection, can you check the wired connection if the same problem. If ever the same issue happens on wired, connect it directly to the modem to check if the issue is with the router or if it is from ISP.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, KuTcH
    What's the firmware installed on your router?
    Did you try resetting the unit?
    Which wireless signal you're connecting to?
    Did you try changing channel?
    How far are you from the wireless router?
    • KuTcH's avatar
      KuTcH
      firmware V1.0.2.40
      yes multiple times
      tried both 2.4 and 5ghz
      tried on 2.4 signals 1,6,11 all same problems tried random channels as well
      roughly 40/50 ft
      and i cant use powerline adapters because i live in a apartment complex, everythings been so frustrating
      • JamesGL's avatar
        JamesGL
        Hi KuTcH,
