aadolfson
Jul 28, 2015Aspirant
Bridging vs. access point
Hello all, I have a new Nighthawk ac1750 router (6700 I believe). I would like to add it to my existing wireless network (a tp-link router). I can either connect it to the existing router wirel...
- Jul 29, 2015
If the 1750 supports AP mode, then connect it with CAT6 to the TPLINK.
Stay away from bridging. You lose bandwidh, and over all, for most, it's lousy experience. You can also use the LAN ports on the 1750 in AP mode. All ports on the 1750 are 1000mb. Hopefully the same on the TPLINK you are using..
netwrks
Jul 29, 2015Master
aadolfson
Jul 29, 2015Aspirant
Excellent, thank you for your input! I will try to place it into service this weekend.
Andy
