Access point
2 TopicsR7000 Media Server Access Point not working
I have Frontier DSL and they give you a lovey router. I also have a Netgear R7000 router. I had the Frontier router in bridge mode and it always reverted back to Routed Bridge. When this happened I lost Internet and it was a pain to fix. So this weekend I decided to set the R7000 as an Access Point, everything works great, till I tried to access the media server. I can access the hdd with //networkdrive/harddrive but if I try to log in using my Xbox or Blu-Ray player it says media server not connected, but it shows the media servers name. Any ideas?Solved5.7KViews0likes3CommentsBridging vs. access point
Hello all, I have a new Nighthawk ac1750 router (6700 I believe). I would like to add it to my existing wireless network (a tp-link router). I can either connect it to the existing router wirelessly or with cat6 (obviously wirelessly would be easier). I am hoping that the Nighthawk will be able to connect to devices wirelessly and hard wired. Looking through the literatureit looks like bridging is not an option, but I am not sure if using it as an access point will allow me to have both wired and wireless clients working through it. Is there another configuration or trick that will let me do what I want to do? Will either of these options negitively impact the transfer of data between the main router and the Nighthawk? Thanks! AndySolved9.9KViews0likes2Comments
