Access point
15 TopicsHardwire the EX7000 instead of wirelessly connecting to the router?
I’m going to try my best to explain my current situation as best as possible since I’m not entirely tech savvy or literate. My current situation is that there are devices that need to be hardwired but the devices are located in separate rooms. One device in my room and one in my brother’s. Now I know that I can use the EX7000 to wirelessly connect to my router and just use the Ethernet ports but doing that cuts down on download speeds. So I was wondering if I can use the Ethernet port in my room and plug the extender into that so I won’t have to wirelessly connect to the router? The current set up is that we have Frontier FiOS and the ONT box is located in our garage. Not sure what that means but the employee from BestBuy said it acts as the modem so that all the Ethernet ports our house can support a router without the need of an actual modem. So currently, all we currently have the Nighthawk X6 plugged into the Ethernet port in my brother’s room and is producing a Wifi signal with internet. We now both have desktops that have no Wifi adapters. So in order to use the internet on our computer we need to be wired. We used to share a room so it was never a problem since the router was in our room but now that we have our own rooms, he kept the router while I have no possible way of accessing internet via wired connection. Since we both game, we prefer a wired connection overall for the best performance. Hence the reason why we never purchased a Wifi adapter for our PC. While trying to look up a solution for my problem, I was constantly seeing answers like using the EX7000 as an access point. However, instructions say to plug it in to a router, which defeats my purpose of buying the extender in the first place since the extender would need to be located in my brother’s room. So long story short, can I hardwire the EX7000 using the Ethernet port in my room so that it can provide internet to my devices that need to be hardwired into the extender?7.6KViews0likes4CommentsConfigure WNDR4300 as base and WNDR3700v3 as access point to create a bridge
I am trying to create a wireless bridge to connect ethernet components in one part of my home to the internet. The intenert connection comes through a cable modem connected to my wireless router WNDR4300. I want to re-purpose a WNDR3700v3 to bring the internet access to devices which do not have wireless capability (DVD Player and Roku) but have ethernet ports. I followed the instructions for each of the routers (different), but I must have missed or done something wrong, because it didn't work. Can someone help? Thanks. JuanSolvedCan't Access Router Login Page--Router in Access Point Mode
I've set my router up in Access Point mode (so that I can connect it to a wifi cable modem whose wifi has broken). Now I can't get to my WNDR3700v4 router login page. I've tried doing it over wife and by connecting ethernet cable straight from my computer to my WNDR3700v4. www.routerlogin.net doesn't work, nor www.routerlogin.com. No luck with 10.0.0.1, 10.0.0.2, 10.0.0.15, (http://192.168.1.1 or http://192.168.0.1. I've seen a few postings like this on the forum...but no solution. Help please? Thanks, AllenSolvedTrying to set up DG834N router as wireless access point for an ethernet printer across Virgin WiFi.
Hello all. I've spent the last few days trawling the advice and instructions given on the web and attempting to complete this task, with much unplugging, replugging and typing of ip addresses. It seems there are lots of tutorials to set this system up with the 2nd router/access point finally being connected via ethernet to the main router but I can't do that at present and I want to know if the 2nd router/access point can be set up wirelessly? Firstly I'm Mac based OS 10.11 with a Virgin SuperHub2 as my main router and here's what i'm trying to do. I have an old DG834N router. My iMac is in my basement and my virgin router is in the room above. The iMac networking is via wifi and works fine across the dual bands. I don't have wired cabling down into my basement & I suspect the electrical ring is seperate to that above ground and therefore powerlines may not work. I recently acquired a ethernet printer (HP officejet 4500 G510g). I want to set up the DG834N as a wireless access point/repeater/bridge in order to connect the ethernet printer and then access this via the iMac and as a networked printer? I've been into the DG834N and done a factory reset (a few times), updated the firmware, set the LAN ip details to match my main virgin router SSID, WPA2, Password, Channel, disabled DCHP and selected a WDS system, most times as a wireless repeater. The furthest I have got is setting up all these details and then attempting to find the printer on the network on my iMac. I presume I need to create a second wifi setting in my network settings with a static ip address and subnet to match the DG834N settings. On occasion the iMac has seen the printer but when I try to install the printer it can't because of network issues as the second static ip address has seemingly 'knocked out' or conflicted with the original 2.4ghz wifi. When I try and seperate the wifi details it changes both at the same time i.e if I try to set the main wifi to 5G it changes the printer wifi to 5G too and the router/printer will only use 2.4g. I've tried to set up a seperate location in my network setting but it still behaves the same way. Also I get frequent, 'another device is using this ip address' messages. I have also re-booted my main router a few times and slowly restarted each device one by one. Oh and I've also connected the printer directly to the iMac to install it in a hope that this would facilitate things if I solved the network problems. Unfortunately I cannot leave the printer directly connected to the iMac permanently as there's not enough space, cabling, power etc. I realise there's a lot of different stumbling blocks (Gotcha's?) in this setup but I'd appreciate any help you can give. Thanks3.5KViews0likes1CommentNetgear wn3000rpv3 not connecting to router via ethernet
So here is my challenge: I have Belkin Router and a netgear wn3000rpv3 extender. the extnder is able to connect to the router fine through wifi and I am able to connect to my devices as well as long as I set it up as an extender. I have a 75mbps connection. by the time I get to my device via the extender.. the speeds are dropping to like 2 to 4 mbps. Hence I thought I will get a cable pulled from my router to my extender. which I did.. and here starts the challenge. My extender is not able to connect to the router as an access point. It just keeps saying " The extender can't connect to the router'. I tried a manual setup using a static Ip. but to no avail. I dont get internet from the extender. My belkin router details are as follows: IP : 192.168.2.1 Mask: 255.255.255.0 DHCP enabled from 192.168.2.2 to 192.168.2.200 Need some help and assistance of how I can setup the access point throught ethernet so I can hget faster speeds. Regards, PK.5.2KViews0likes7CommentsAmazon says EX2700 can be used as access point, thru software switch (it has no hardware AP switch)
Also, I have gathered from a few Amazon reviewers that EX2700 can easily be set up in AP Mode, by simply connecting it to wireless modum/router with ethernet cable. Can someone here provide or point me to a simple step-by-step procedure for setting up my new EX2700 (Essentials Edition) as a wireless access point? Thanks in advance for any help. hl-louisiana7.4KViews1like2CommentsConfigure route to be in the same LAN (N600 WNDR3700)
Hi, I have a Gateway router A (ProSafe (FVS336G) and a wireless router B (WNDR3700). My network topology is: (WAN IP: 10.xxx.xx.xxx) A (LAN IP: 192.168.1.xxx) <---> (WAN IP: 192.168.1.xxx) B (LAN IP: 10.0.0.xxx) <---> wireless device (IP: 10.0.0.xxx) The firmware on router B is V1.0.7.98NA. Current topology works. Every device has access to the internet. However, I need to stream data or remotely log in from device (whose IP address is 192.168.1.xxx) to device connected to router B. Now it's hard to achieve this (if possible) because wireless device is behind the router B. I am a newbie in these internet protocal stuff. I did some research online and think my option is to disable the DHCP service on B and make it an access point. However, when I go to the LAN setting pages of router B, and try to write the LAN IP as 192.168.1.xxx or try to uncheck "Use router as DHCP server", it reports conflict with WAN subnet IP. I understand it's obvious that on router B, I am setting its LAN IP in the same subnet as its WAN IP, which it's rediculous. But why unchecking the DHCP and make it an access point also doesn't work? I also saw people mentioned in other posts that the issue is using B as a DNS server. They disabled it and it works. But I don't know how to do this. I am not sure how to achieve my goal now. That is, making the ip address of every wireless device as 192.168.1.xxx, remaining in the same subnet of devices connected to A. I sincerely appreciate any suggestions! Best, YanSolved7.5KViews0likes2CommentsTrouble setting up extender as access point with Xfinity modem/router
I have been unable to set up the above extender as an access point. I have an Arris Xfinity (on the X1 platform) modem which also functions as a router. I connected the modem/router to the extender with an ethernet cord as instructed, then attempted to connect to the extender. This brought me to the webpage to set up as either an extender or access point. I selected access point. After doing that I received a message telling me that a connection could not be established with the router, which is where I am stuck. I am not sure if it's something with the Xfinity modem that prevents me from setting it up in this manner, and have been unable to find anything addressing this specific issue. Any insight would be much appreciated.3.1KViews0likes1CommentUnable to obtain IP address from WNDR4300v2 after setting as access point
I have to admit, this is my first time trying to extend my wireless range, and I'm confused by the whole access point concept. It seems like what I really want is a repeater, but that mode isn't available on the 4300v2. I have two 4300v2 units. One is set as a normal wifi router. I want to setup a second 4300v2 to extend the range of this "base" router. Ideally, I want the wifi SSID and passcode to be the same between the two wifi units. So the wireless client can move seamlessly between the two without having to make new connections. When I follow the instructions to set the second unit as an Access Point, it gets assigned an IP from the original router as 10.0.0.1. I then take the access point and move it away from the original router. Just within wireless range of the original router. I don't connect anything to the WAN port of the AP. My wifi client has good signal from the AP, but is unable to obtain an IP address. What am I doing wrong? Thanks!Solved4.3KViews0likes3CommentsWNDR4000 as an Access Point
Hi, I've setup my Netgear Router as a wireless Access Point & when I log in & look at connected devices, they all show up as Wired Devices & they are the same devices as my Router shows. Is this correct? I have the Netgear SSID set to the same as my Router & a static IP address. I can log into either one, but not sure I have it setup correctly?? Any ideas? Thanks3.5KViews0likes1Comment
