Sunshineqaf22
Mar 22, 2021Aspirant
Can see wifi and conect but no internet
So I Got The Modem WiFi Router Combo. I can See the WiFi and connect to It but It says no Internet. I have followed all the troubleshooting and unless I'm connecting a computer It isn't Allowing Internet. I'm Frustrated As Hell
who's your isp?
did you get it activated through your isp?
do you have a screen snip of the modems cable connection page and event logs?
Do wired devices work?
- Sunshineqaf22Aspirant
You thru out a lot of rapid fire questions there. All the computers connected to wifi no problem only phone and Tv's will not connect. I followed all the suggestions for troublshooting and netgears suggestions but none work. It just will not allow anything other than computer to have internet access.
So computers connecting to wifi work fine?
Have you connected more than 1 computer to the wifi?
What error do the phones/tv give you when you're trying to connect?
Does the tv connect if you connect it with a ethernet cord?
- Sean901Tutor
Similar issue here all weekend. Some devices connected fine, yet on others told there's no internet connection. Same system connects then gets thrown off internet even while other connected devices are fine. Power cycled all systems repeatedly, no change. Feels a lot like there's bugs in the firmware update that need to be addressed.
- plemansGuru - Experienced UserThe RBR50 is a different device from a C6300. Once a mesh system and the other is a modem/router combo device. I'd encourage you to start your own thread in the orbi forum
- Sean901Tutor
Understood. Thanks for the tip. Already have a post over there and wasn't paying attention to which subforum / device folder this was in. Cheers.
