TitaCorrales
May 18, 2017Aspirant
Can't log in my router with laptop
Hi, I am having a problem trying to log in into my router via my laptop with windows 10. I can log in with my iPad or iPhone using the IP address but when I want to log in with my laptop thru my wifi I can't. Do you know if I need to change something on windows10?
I think I found the problem. I unistalled Kaspersky and I was able to log in. I am reinstalling it right now, let see if that fix the problem.
- JamesGLNETGEAR Employee Retired
Hi TitaCorrales,
Are you getting any error message when trying to access the UI?
TitaCorrales wrote:Hi, I am having a problem trying to log in into my router via my laptop with windows 10.
What happens when you try?
Can the laptop see the wifi?
This discussion may spark off a few thought:
Netgear D6400 DSL Wireless Modem Connection issues - NETGEAR Communities
Someone else with naughty laptops.
- TitaCorralesAspirantYes. I receive a message that is the proxy or firewall. But I checked and everythings looks normal. I can connect to the wifi and surf the internet. The problem is when I want ti log in the router sertings. I can log in with my iPhone but not with my laptop.
TitaCorrales wrote:
Yes. I receive a message that is the proxy or firewall.A message in Windows?
That can be very picky when is comes to network settings.
So, what do you think it is. It happens with the explorer and with chrome
- LeeHProdigy
Are you running Kaspersky AV software?
- VE6CGXMaster
Then try with wired connection. If it works. Try ping the router via wireless. Not working on wireless? The do ipconfig /all to see what's going on. Any AV program on your laptop running?
I tried wired connection and is the same
this is the message that appears:
This site can’t be reached
The connection was reset.
Try:
- Checking the connection
- Checking the proxy and the firewall
- Running Windows Network Diagnostics
ERR_CONNECTION_RESETI already check connection and is working, I can ping the router. The proxy is unchecked, I include google on the firewall, run windows network diagnostics and it said that there is no issues.I am using kaspersky AV- TitaCorralesAspirant
- TitaCorralesAspirantWell it was working fine. And suddendly I couldn't log in. I tought was something else.
Hi TitaCorrales,
If you have Kaspersky Antivirus, you may try the KB below.
https://kb.netgear.com/30012/Unable-to-access-router-management-page-with-Kaspersky-installed
