rochrunner
Mar 21, 2021Tutor
Change from AP Mode to Router Mode
I've been using my R7000P for a while in AP mode, connected to a router supplied by my service provider. However, if I "cut the cable" as planned, I'll be connecting directly to a normal cable modem and will have to switch to Router mode. What is the best way to do this? I see that there is an option in the Advanced Setup section to make the basic Router/AP/Bridge setting -- is changing this all that would need to be done?
I also notice that the IP address of the router is 192.168.0.6 but don't see where that gets set. Would I need to change this also?
I suppose that another option would be to just do a "factory reset" on it and install it as if it just came out of the box. Any comments?
> [...] is changing this all that would need to be done?
Sounds right to me.
> don't see where that gets set. [...]I'd guess that it comes (DHCP) from the main router to which your
R7000P-as-WAP is connected. ("Get dynamically from existing router"?)> [...] Would I need to change this also?
It should change automatically when you change the mode and the
environment.> I suppose that another option would be to just do a "factory reset" on
> it and install it as if it just came out of the box. [...]Yup. Always good as a fall-back, if more subtle techniques fail.
The pain depends on how many settings you'd need to restore manually.- plemansGuru - Experienced User
When you set the r7000P in access point mode, it got the ip address from the router its connected to.
If you switch it back to router mode, it *should* change to its defaults ip address.
Fairly simple to do.
Or you can do the factory reset and reinstall. That's always an easy option as well
Yeah, as pointed out, the problem with the factoy reset would be the other settings that I'd have to redo, although I don't think there are that many (SSIDs and passwords, etc.).
You can always try it with just switching it out of access point mode.
If it has issues, then try the factory reset
> from the router its connected to.It did, if you chose "Get dynamically from existing router." If,
instead, you chose "Use fixed IP Address (not recommended).", then you
specified a static address (and other parameters) yourself. Presumably,
you'd remember doing that if you'd done it.- DanG_NOLAAspirantCurrently both are AP. I switched the R8000 back to router but when I connect to it, it apparently issues an illegal ip or none at all. The default IP won't talk to it. The two netlogin addresses don't work either. None of 192.168.1.1, .1.254, .0.1, nor .0.254 work. I rebooted it 3 or 4 times. No help. I hit the reset button, it returns to AP mode with all my settings intact. After I deselect, AP mode and restart, hooked up to Ethernet port 2, what else do I need? My laptop is set to get IP number from router.
