DianaNashif's avatar
DianaNashif
Changed router password not can't login
Having trouble with my router.  Did login using the default login. Once in there was a firmware update that I processed.  Had to then log back in no problem.  Next I changed the router password and did enable recovery questions option. Then it logged me out, but now I can't log back in with the old or new password.  Used the router recovery and is shows the right new password.  Still no luck!!!
Tried 3 browsers, cleared internet cache and used both wireless and wired connections.  Also an ipad too!
Now what do I do?
Thanks for any expert help,
Diana
    • DianaNashif's avatar
      DianaNashif
      Thank you!
      Tried that and still couldn't get in. Gave up and bought a new NightHawk X6S. Getting better signal now so I think the old one was on it's way out.
      Cheers,
      Diana
