gllong21620's avatar
Jun 11, 2021
CM1000 losing connection with R7000
Hello all, my setup of R7000 with CM1000 and EX6400v2.  Several times a day, the router losing connection with the modem.  The issue does not seem to be an ISP issue as service to modem is in place even as router drops out.
i have rest the router via Nighhawk app.   I change connection cable between modem and router.  I moved extender further from router and modem.  Router and modem are using most up to date firmware.
solutions I have not considered?   I am really stuck.  Thanks
  • plemans's avatar
    What actual firmware is on the R7000?
    Its not always "on the latest" or sometimes the latest isn't the best for it.
    Do wired connections drop as well?
    • gllong21620's avatar
      gllong21620
      Tutor
      Thanks for your question.  R7000 firmware is V1.0.11.106.  I do not have any wired connections
      • plemans's avatar
        You might try installing the latest 1.0.11.123 firmware. Then do a factory reset and reinstall and see if it helps.
