BondsteelRS
Nov 10, 2020Tutor
Coaxial a
Hi,
Is there available any kind of adapter that could convert the coaxial to an cat5 connection?
the place that we are in use only cat5 connection, the internet provider can't help, so the only way is to get adapters in any are.
Your desciption wasn't very clear.
Are you trying to use a coaxial run as a ethernet run? If so, you could look into moca adapters. (ethernet over coax)
Found them, yes, that was what I meant.
thanks a lot for your help.
Glad that's what you're looking for!
