WacoJohn's avatar
WacoJohn
Luminary
Mar 17, 2019
computer does not see USB drive connected to XR500
There are 5 windows 10 machines on home network.  All 5 were set up the same.
The problem machine was working fine along with the other 4 until something catastrophic happened and I had to install W10 from the recovery thumb drive.
Simply put, that machine will no longer detect the USB drive connected to the router, at least not the way it did before and like the other 4 computers.  One thing I notice though is the drive device used to show up in NETWORK in explorer on all machines.  It now doesn't on any machine(????).  Sharing options are exactly the same on all 5 machines for what it's worth.  It would seem the problem is not within the router since I have changed nothing there ... I'm pretty bewildered.
Might help to know ... back when the universe was stable, all I did was find the readyshare device in Explorer's Network and then map it to M: ... at least that is what I recall.  Now, it doesn't appear in Network on any machine, but the shortcut to M: still works on 4 machines.
Any help is greatly appreciated in advance/
The differences are highlighted in yellow above.  As I understand it, it is simply supposed to work by plugging in the drive to the router (though maybe not).  Wondering if I just need to reset the router (which DOES have the latest firmware).  Any help is appreciated in advance.
  • Gearhead support found the problem.  It wasn't easy.  Turns out an item in Group Policy editor needed to be turned on.  SORRY, don't know what it was .. something about sharing, the remote access tech moved too fast.  Once he made the edit, it works perfectly.
    I want to sincerely thank EVERYONE who tried to help me.  You guys are the best.
  • Can't see ANY pictures until a NG Moderator approves it.
    However, my EDUCATED GUESS is the PC that was RESTORED had SMB 1 turned OFF. Turn it back on and I think it will solve the problem.
    CONTROL PANEL => PROGRAMS AND FEATURES ==> TURN WINDOWS FEATURE ON OR OFF, scroll down to SMB 1.0, expand the selection and turn on CLIENT ONLY... Press OK... should fix it.
    • WacoJohn's avatar
      WacoJohn
      Luminary
      Thank you, Sir for the quick reply.  Following your instructions, things are much improved but still have a connect problem.  The problem is on a machine with W10-64 PRO.  The others are W10 Home in case that is important.
      When I click NETWORK in Explorer, READYSHARE is listed along with the other network devices.  When I click on it it does not expand to subfolder USB_Storage ... as do the other machines, but instead give an error:
      Windows cannot access \\READYSHARE
      Check the spelling of the name (blah, blah, blah)
      Error code 0x0070035
      Troubleshooter cannot find the problem.
      You should probably know when I checked the status on SMB 1.0, nothing was checked.  I checked CLIENT ONLY and have now made this progress.
      Looking at the OTHER machiines, I noticed this PRO machine also has a setting for SMB 3 which is/was ON, .. so I left it alone.  The other machines have no such item.
      Pictures provided just in case you can see them.
      • IrvSp's avatar
        IrvSp
        Master
        I'm guess again. I've got a mix of Home and Pro W10's running here, ALL are working fine.
        I'm guessing the PRO is not on the SAME NETWORK NAME as the other PC's.
        Open a CMD prompt on the Pro and another PC using the Windows key+R and enter CMD.
        On both PC's enter "net config workstation" in the CMD prompt.
        Check the line "Workstation domain" to see if they match.
        Also in each run "net view". Should look like this on both PC's:
        C:\>net view
        Server Name Remark
        \\Home PC name
        \\Pro PC name
        \\READYSHARE readyshare
        The command completed successfully.
        Above first two line are examples, should see ALL PC's on the LAN and READYSHARE on all PC. Don't see READYSHARE on the Pro machine, and they are the same network name, has to be something else? Report back.
