Herbert323
Mar 24, 2017Aspirant
Confused about setting up Port Aggregation
Hi, I just got a new S8000 switch that I wish to connect to my R9000 and use Port Aggregation. I am a bit confused though. Maybe someone can help.
My goal:
1. Connect my switch to my router to use Port Aggregation on ports 7&8. Will this then replace the normal cable thT goes from the router to port 8 and act as the internet connection?
2. Freeze the IP address on the switch. Do I have to go through the process in the manual or can I just set it with the router?
3. Here is the hard part. I have two Drobo B810ns. The instructions are a bit vague so I'm not really sure I even have to setup Port Aggregation as the devices come with two Ethernet cable connections and the way the manual reads it looks as if I can set this on the device alone with a formal setup on the router and or switch.
4. Lastly, how can I go about linking both Drobos if the router only allows Ports 1&2 for link Aggregation?
Thanks
Herbert
- I actually figured out what was going on with mine. Once I found and installed the beta firmware, the static lag option showed up. I changed that setting and then connected and everything seems to be running fine and port aggregation says that it's active.
- storm1985Prodigy
NO. the port aggregation is only applicable for LAN and there is a dedicated WAN port to receive internet connection from your modem.
if you mean set a static IP address on the switch, you have to do this on the switch. see manual page 14-15
- there should be an adapter settings on your drobo where you can configure link aggregation IF it supports LACP. You may check the drobo manual for more info or call their support
here's an example on how to setup with other NAS brands:
Port Aggregation with Synology NAS on your Nighthawk router Port Aggregation with QNAP NAS on Nighthawk router How do I enable LACP on my ReadyNAS?
-the network diagram should be modem -> (WAN) R9000 LAG 1,2(LAN) -----LAG 7,8 S8000 ------ LAG other ports to Drobos
this means on your switch you have to create LAG Groups 1 for the router then another group/s for the Drobos
- socalspartanAspirant
How did you get this to work? Can you tell me step by step? I followed the procedure on the netgear website but it wont work. I first disconnected the switch from the router. Setup LAG on the switch at port 7 and 8. Enabled link agregation on the r9000. Connected the cables, 7 and 8 on the switch to 1 and 2 on the r9000, then everything starts flashing and no internet on both the switch and the router. What step am I missing?
- jak0lantashMentor
EDIT: sorry, didn't read properly :D
- cdominguez2007Aspirant
I'm also trying to setup link aggregation and I can't get it to work. I followed every procedure in that article, until I get to step 5 to set up LAG on my X10 router. It said to click "Enable (Static LAG)" The only option I have on my screen is "Enable (LACP- IEEE 802.3ad)". Even when I enable that and connect the wires, the port aggregation never says active, but I no longer have the network loops that were shutting me down. I'm at a bit of a loss currently.
- JamesGLNETGEAR Employee Retired
Hi cdominguez2007,
Try to check as well this KB.
- cdominguez2007AspirantI actually figured out what was going on with mine. Once I found and installed the beta firmware, the static lag option showed up. I changed that setting and then connected and everything seems to be running fine and port aggregation says that it's active.
