trx-4-defender's avatar
Nov 30, 2019
connect to caomcast ( xfinity) modem
I just install Nighthawk R8000 to Xfinity modem.
- work for couple hours,
- still have 2,4G from  comcast
- R8000 give me one 5Ghz band
Install nighthawk app and stuck at login to 2.4Ghz
Then nothing connect to internet.
Unplug the R8000 and everything back to normal ( without Nighthawk R8000)
Please help to install the router, anyone who is succesfull connect to xfinity modem, your help greatly appreciate.
Any good procedure
Thanks
  • microchip8's avatar
    microchip8
    Dec 01, 2019
    your Netgear "modem" is not a modem but a router. Your ISP provided device is a modem/router combo. Connecting these two together without setting your ISP modem/router into bridge mode creates a double NAT which you should avoid
    The firmware version of the R8000 can be found either in the app or the Web GUI at http://192.168.1.1
    Your ISP modem/router most likely has a label on it with the device model
  • You're running 2 routers and creating a double NAT. Set your ISP modem/router to bridge mode if possible and use the R8000 as the router. Also, it would be useful to know the ISP modem model and firmware version on the R8000
    • trx-4-defender's avatar
      trx-4-defender
      Thanks for your respond,
      I need of a procedure of how to setup,
      When I set up, it just went very fast and smooth untill I see only one band which is 5Ghz,
      I then down load the nighthawk app then I was be able to see other 2 bands
      But then I would lost the internet connection, so I unplug the ethernet cable from the comcast modem and go back to the original setup of comcast, which is their modem/router.
      I don't know where to get the info of firmware, my netgear modem is R8000, ac3200 X6
      Thanks
        microchip8
        Master
