bm22
Dec 17, 2020Aspirant
Constant Errors Only with NBA 2K21
I get disconnected from every NBA2K21 online game I try to play. I keep getting the same error codes despite not losing connection to the internet. I have 1GB internet and am connected to the router ...
try this. install version 1.1.0.86 of the firmware to it. Make sure to do it over a hardwired connection. Once installed, factory reset the router and do a clean install (not from a backup). Disable auto-updates.
Once reinstalled, put the consoles IP address into the netgears dmz again.
run it. see how it works.
Ok. Can you clarify the DMZ part? I'm only seeing "Default DMZ server" as a DMZ option. So just make sure that's checked and enter the console's IP into it? My console's IP address isn't the one entered for it currently, could that be a potential fix?
