Hydro89
Jan 25, 2022Aspirant
devices connecting
So I have a nintendo switch and it will not connect to the server. The password is right I already tried with nintendo support and they are no help.
Won't connect to the server?
Or won't connect to the router?
A little unclear on what is actually happening.
what firmware is on the router?
What modem/gateway is the router connected to?
- Hydro89Aspirant
It connects to the router but not the server. I need I think to open the port forwarding thing.
Tell us in a bit more detail what is going on.
How about the other questions from plemans? In particular, what modem/gateway is the router connected to?
What are the messages that you see when you connect to the router?
What makes you think that?
Talk of "the port forwarding thing" doesn't mean much unless you know what you are doing. For that you need to ask the people who support the Nintendo switch.
This may help:
Search - NETGEAR Communities – Nintendo Switch
And what happens when you try? Any helpful error messages?
Connect how? Wired? Wifi?
- Hydro89Aspirant
its wifi
