frizzo's avatar
frizzo
DLNA on XBox One fails to go to the next video when the previous one ends.
I have an external hard drive connected to the router and I share its contents (most videos and photos) via DLNA.  I use XBox One as the client, specifically its Media Player application.  I have 10 video files (about 30 minutes to an 1 hour each) in a folder.  I play and watch the first one.  Once it finishes playing, XBox tries to go to the next file in the folder.  Unfortunately, it throws up an errorerror message, stating that it can't access the server.
However, if I then close out and go to the root of the DLNA server and then go back to my folder, I can play the next video fine.
What can I do to make the DLNA be able to play the next file?
  • James,
    Turning DLNA off and then back on ended up fixing the problem.  I never tried the solution you mentioned.
    Robert
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi frizzo,
    If you connect the drive directly to the Xbox, will you be able to play the files continuously or getting the same error?
    JamesGL
    Community Team
  • JamesGL's avatar
    JamesGL
    Hi frizzo,
    We’d greatly appreciate hearing your feedback letting us know if  you need further assistance.
    JamesGL
    Community Team
    • frizzo's avatar
      frizzo
      James,
      Robert
      • JamesGL's avatar
        JamesGL
        Hi Robert,
        If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
        JamesGL
        Community Team
