cosmothunder's avatar
Oct 31, 2021
DNS_PROBE_FINISHED_NXDOMAIN
Ever since i updated to the new firmware
Firmware Version
V1.4.2.84_1.3.42
I've had nothing but issues. problem connecting to websites, problems connecting to discord and certain games jsut not wanting to work. I've tried something called releasing IP, flushing and renewing ip and it works for a few mins then im stuck again with issues. Its driving me crazy. Please someone help me!
Thanks
  • FURRYe38's avatar
    So if this problem started with a recent firmware update, you can downgrade back one version of firmware to see if the problem goes away...
  • FURRYe38's avatar
    What router model are you referring too?
    • cosmothunder's avatar
      cosmothunder
      Guide
      Router is Nighthawk X6S
      AC3600 Model# R7960P
      Modem is Nighthawk CM1100
      When i updated my firmware on the router thats when all these problems started.
      • FURRYe38's avatar
        Has a factory reset and setup from scratch been performed since last update?
        Power OFF the modem for 1 minute then back ON.
