beautifulday's avatar
beautifulday
Do i need to update R7900 from costco
Greetings!
I was just told by Cox Cable that I needed to reset my r7900?  that I had a glitch in it?  do I also need to update it?  I appreciate your time and expertise.
  • Hi beautifulday,
    Check with the printer manufacturer if you need to update the software or driver of the printer.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi beautifulday,
    May I know what issue or problem you encountered with the router?
    • beautifulday's avatar
      beautifulday
      Good evening!
      I was having trouble with the printer disconnecting from the router.  When I called my cable company, they suggested updating the software.
      Do I need to?  Since I wrote that, I haven't had any problems.  Thank you for your time and assistance.
      Please just email me directly.  [email protected]
      Enjoy your evening!
      Marianne
    • JamesGL's avatar
      JamesGL
      Hi beautifulday,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      • JamesGL's avatar
        JamesGL
        Hi beautifulday,
