rkruz's avatar
rkruz
Apprentice
Feb 23, 2022
Does Router Return "Unavailable" to sender with each "DoS attack" log?
I turned on my PC and immediately got a series of DoS attack log entries.
Does each entry in the log mean that the router has returned a message for each log entry that the network is unavailable for some message similar?
[DoS attack: ACK Scan] from source 34.149.211.227,port 443 Wednesday, Feb 23, 2022 07:33:43
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 07:31:36
[DoS attack: snmpQueryDrop] from source 34.77.162.13,port 57789 Wednesday, Feb 23, 2022 07:22:00
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 07:18:15
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 07:11:14
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 06:57:14
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 06:46:31
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 06:35:14
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 06:22:31
[DoS attack: ACK Scan] from source 205.185.216.42,port 443 Wednesday, Feb 23, 2022 06:08:58
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 06:06:34
[DoS attack: RST Scan] from source 168.90.208.68,port 37168 Wednesday, Feb 23, 2022 05:59:46
[DoS attack: RST Scan] from source 44.241.40.79,port 443 Wednesday, Feb 23, 2022 05:54:56
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 05:53:51
[DoS attack: ACK Scan] from source 34.149.211.227,port 443 Wednesday, Feb 23, 2022 05:48:32
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 05:37:54
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 05:25:11
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 05:09:15
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:05:05
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:05:04
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:05:03
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:59
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:58
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:54
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:53
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:52
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:51
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:50
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:49
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:45
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:44
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:43
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:42
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:41
[DoS attack: TCP SYN Flood] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:40
[DoS attack: snmpQueryDrop] from source 104.152.52.180,port 41471 Wednesday, Feb 23, 2022 05:04:32
[DoS attack: snmpQueryDrop] from source 192.241.206.177,port 37819 Wednesday, Feb 23, 2022 05:00:54
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 04:56:32
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 04:40:36
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 04:30:35
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 04:18:19
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 04:06:34
[DoS attack: ACK Scan] from source 34.149.211.227,port 443 Wednesday, Feb 23, 2022 04:03:43
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 03:54:33
[DoS attack: RST Scan] from source 54.148.137.175,port 443 Wednesday, Feb 23, 2022 03:52:40
[DoS attack: RST Scan] from source 54.148.137.175,port 443 Wednesday, Feb 23, 2022 03:51:07
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 03:43:16
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 03:26:08
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 03:14:36
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 03:00:54
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 02:47:56
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 02:36:23
[DoS attack: ACK Scan] from source 34.149.211.227,port 443 Wednesday, Feb 23, 2022 02:29:14
[DoS attack: snmpQueryDrop] from source 204.42.253.130,port 49502 Wednesday, Feb 23, 2022 02:26:46
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 02:19:16
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 02:07:43
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 01:54:56
[DoS attack: ACK Scan] from source 35.244.184.98,port 443 Wednesday, Feb 23, 2022 01:54:16
[DoS attack: RST Scan] from source 99.84.224.120,port 443 Wednesday, Feb 23, 2022 01:52:20
[DoS attack: RST Scan] from source 35.155.16.166,port 443 Wednesday, Feb 23, 2022 01:49:22
[DoS attack: RST Scan] from source 35.155.16.166,port 443 Wednesday, Feb 23, 2022 01:49:21
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 01:38:50
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 01:19:44
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 01:00:38
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 00:48:53
[DoS attack: ACK Scan] from source 34.149.211.227,port 443 Wednesday, Feb 23, 2022 00:40:29
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 00:37:08
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 00:25:23
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 00:13:38
[DoS attack: Fraggle Attack] from source 10.72.120.1,port 67 Wednesday, Feb 23, 2022 00:03:30
  • No. It is blocking the "attacks". It doesn't return anything but sends a DROP in its firewall and logs an entry
    NETGEAR's DoS protection is famously know for many, many false positives. Some can even come from your ISP or your own devices on LAN/WiFi. Always look up the IP address it reports to see if it's legitimate or not. If you have problems, disable DoS "protection" clompletely (you're not losing much at all) to relieve the router. If you want to keep it on, at least disable the logging of these "attacks"
    PS: I run 4 years without this faulty DoS "protection" and never had any issues
    • rkruz's avatar
      rkruz
      Apprentice
      Understood.  Thanks for clarifying.
