bzyc
Nov 26, 2021Tutor
EX6250 Mesh Extender doesn't connect anymore
Most recent Android app update made me unable to use my mesh extender EX6250. I've since factory reset the extender, and tried to reconnect, but the app keeps crashing when "personalizing settings" during setup. Have also reinstalled Android app, but to no avail. So now the Mesh Extender doesn't work. WPS can only connect 2.4ghz but not 5ghz.
bzyc wrote:
I've since factory reset the extender, and tried to reconnect, but the app keeps crashing when "personalizing settings" during setup.Netgear's apps are famously flaky.
Have you tried setting it up with a browser? Wired is preferable, but if you can connect to the wifi that may also work.
One configured you may find that the app works.
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Please use this link to the main forum product list to review and choose where to make your posts.https://community.netgear.com/t5/NETGEAR-Forum/ct-p/en-netgear
Thank you. - plemansGuru - Experienced User
What android app are you talking about causing the issues?
Are other devices having issues or just the one device?
