Ant30's avatar
Ant30
Extending Wifi into external garage - help?
Hello all.
Wondering if someone can help. I have a R800P in my property which in the house has amazing signal strength. We’ve just had our external garage converted (around 5m from the house) and we’re struggling to get any wifi signal outside. I purchased a EX7500 and placed it just beside the back door however it is not extending the signal in any way.
Given the current tech we have in the property can anyone suggest anything else I can purchase to extend into the garage? I’ve got a PS5 and TV and iMac in there as it’s my office/chill room so need a decent signal.
Thanks very much!
  • FURRYe38's avatar
    Any chance of getting a CAT6A lan cable from the house to the garage? This would be preferred. Then you can have a hard wired connection to the garage, then place a 5 port Gb LAN switch in the garage and then connect a wireless AP like a EX7700 in AP mode in the garage that connects wired to the house that would provide wifi coverage in the garage area.
    • Ant30's avatar
      Ant30
      Thanks for your suggestion buddy. I have thought about this but would mean either digging up the garden (my garden is higher level than the garage) or going out of the roof down drainpipes digging up the perimeter etc. The garage is on the same electricity supply, are those plugs you can get any good?
      • Kitsap's avatar
        Kitsap
        Master
        The proper term is powerline ethernet adapter.  Search for that on Amazon and you will get plenty of results with ratings and answered questions.
        Some are ethernet in and ethernet out, others are ethernet in with ethernet plus wi-fi out.  Many applications are very successful.  Occasionally they don't succeed for the situation where they are applied.  Your application seems ideal.
