AlanKUO
Dec 22, 2016Aspirant
How to disable R7000 ssh serivce ?
Hi ,
Does any one know how to disable R7000 ssh serivce?
My R7000 be enabled ssh server and I cann't login it .
AFAIK, the R7000 doesn't have an ssh server. To be safe, you should reinstall firmware to wipe out anything that may have been installed by a hacker. You should install the latest firmware in order to pick up the fix for the big security vulnerability that was publicized last week. Download the firmware here.
- clithesProdigy
If you can't login a Factory Reset may be the only way. This will unfortunately erase all your settings as well.
Page 192
Hope this helps
- AlanKUOAspirantHi Clithes,
I had tried factory rest but ssh server on my r7000 still be enabled. Does ssh server default setting enabled? Or someone hacked my r7000 and enabled ssh (dropbear ssh server)AFAIK, the R7000 doesn't have an ssh server. To be safe, you should reinstall firmware to wipe out anything that may have been installed by a hacker. You should install the latest firmware in order to pick up the fix for the big security vulnerability that was publicized last week. Download the firmware here.
- AlanKUOAspirant
Hi TheEther,
I update the latest firmware OTA when I log on r7000 web at this morinig. but ssh still enabled. I downloaded the the latest firmware and reinstall it just. SSH service be disabled on my R7000. Thanks a lot!!
