withalligators's avatar
Apr 20, 2015
How to maximize speeds with a Broadcom AC card and R7000?
Hello all,
I've upgraded my motherboard to a Asus Maximus VII Impact with an onboard Broadcom 802.11AC Network Adapter. I believe it is model BCM43XAC_NT61 based on the device ID.
On my 5GHz band network, it will connect and if I right click teh network and click Status the speed is listed at 866.5 Mbps. If I hover the mouse over the network, it only lists it as 802.11n and not ac. I only get 1-2 bars on the 5GHz band though. With this, I can download from Steam at up to 4.2 MB/s. I feel like it should be much greater.
On my 2.4Ghz network, I get 2-4 bars, speed is 144.0 Mbps, and I get up to 3.9 MB/s downloads.
I have WMM enabled on the router, but, but unsure of what else to tweak for this card. I had changed a bunch of settings for my previous intel 7260, but erset it after I got rid of that.
Any ideas?
Cheers,
Alex
  • I changed all the settings. Immediately made the signal jump to four bars, and then drop down slowly to 1 or 2. Not much difference in download speed.
    But, I got a new modem from Optimum, one with Docsis 3.0, the Arris TG862G, and it allowed my dl speeds to go up to around 7.0 MB/s. Much better.
    Should I look into getting one of the high end Surfboard modems to further increase speeds?
    And is there anything else you guys can think of regarding the Broadcom card or the router to further increase DL speeds?
    This is the antenna that came with my motherboard. Would I be better served with some standard antenna?
    Will putting aftermarket antennae like this do anything or is it just gimmicky? How come they don't list it as 802.11ac compliant in the listing?
    Thanks again
    Cheers
    Alex
