Nicolus008
Dec 23, 2021Aspirant
How to separate RBR40 2.4GHz and 5GHz
I cannot to install Alro pro 4 cam, because it is use the 2.4 GHz.
I have two question.
How To disable the 5GHz, because there do not have the checkbox to click the disable the 5GHz.
How to crate two SSID, one for 2.4GHz and other one is 5GHz.
Thank you
You shouldn't need to disable the 5ghz or seperate them out.
Did you contact Arlo for support with connecting their camera?
- Nicolus008Aspirant
Hi Plemans,
Thank you for your replied, I sent the message to arlo for setting isses.
But RBR40 can separte and I can choice use 2.4GHz or 5GHz?
I know other brand router can setting it.
No. the orbi series you can't seperate the bands.
