softerist's avatar
softerist
Apprentice
Jun 07, 2017
Hybernate External HDD of PLEX
Hello,   Is there any way that I could set up my external Western Digital connected via USB to my NETGEAR X10 router to hybernate or sleep, while PLEX or other proceses from him are not used? My H...
  • ElaineM's avatar
    Jun 09, 2017
    Welcome to the community, softerist
    Unfortunately, there is no setting on the router that would make your external drive to put on hibernate/sleep when not in use.
    You may just safely remove it.
