softerist
Jun 07, 2017Apprentice
Hybernate External HDD of PLEX
Hello, Is there any way that I could set up my external Western Digital connected via USB to my NETGEAR X10 router to hybernate or sleep, while PLEX or other proceses from him are not used? My H...
softerist
Jun 09, 2017Apprentice
Thank you for your answer.
I hope this will be implemented in the near feature.
ElaineM
Jun 09, 2017NETGEAR Employee Retired
You're welcome.
I suggest that you submit it under our Ideas Exchange board.
- softeristJun 11, 2017Apprentice
Ideas Exchange board does not have a thread for R9000 router. So I can't submit it... this sucks bad.
- ElaineMJun 12, 2017NETGEAR Employee Retired
The board is not product specific. You can just simply create one for your request.
Just make sure to indicate the model either in the title or in the textbox.
