VA13's avatar
VA13
Internet drops from Samsung TVs with Nighthawk R7000
Hi,
I have 3 Samsung TVs and Nighthawk R7000 router. All Samsung TVs are connected via Ethernet cable. I have noticed that internet drops off randomly from all 3 TVs. All the rest of the devices on wifi or connected via ethernet work fine though and this issue is limited to Samsung TVs only. To be able to connect TVs again I have to restart my router. I have tried connecting another router from ISP for a month and since doing that this issue has been resolved however i prefer to use Nighthawk router instead.I have read few discussions and heard people recommending entering Static IP address or DNS number on TV but I'm not sure what IP address I should enter. Any help will be appreciated.Thanks
  • plemans's avatar
    1. what modem/gateway is the router connected to?
    2. what actual firmware is on the router?
    • VA13's avatar
      VA13
      Hi Plemans,
      The default gateway is 192.168.1.1 and I upgraded the firm last week to V1.0.11.123_10.2.100.
      Thanks
      • plemans's avatar
        the gateway is what modem/ont/etc that the router connects to for its signal.
        After the firmware upgrade, did you try a factory reset?
