manjulapra
May 12, 2021Aspirant
IP range mixup
Hi,
Recently switched my modem. Got a ATT modem+router. Did a passthrough and configured the network. When I hooked up, router picked 10.0.0.1 as the IP range, probably due to a conflict before I set the passthrough but I am fine with it. All devices connected and working fine, except:
One Amcrest camera and my PiHole is given it's previous IP addresses starting with 192.168.1.x.I don't know why their IP addresses did not automatically change. All the other devices have 10.0.0.x IP addresses. I wanted to give 10.0.0.x IP for the camera and PiHole but can't fine a way how.
Please help. Thanks in advance.
Thanks for the help. I was able to resolve by configuring a different IP range for the modem. It seems the ATT modem does not function just as a modem.
- microchip8Master
Did you unplug these devices and then plug them in again?
What firmware is on the router?
If your modem is in bridge mode, the router should use its default 192.168.1.1 address
To add to what microchip8 says, the fact that your router opted for 10.0.0.1 is an indicator that it probably saw another router when you set up the R7800.
Netgear's setup process tries to be intelligent and looks for anything squatting on 192.168.1.1. If it find something, it tries to avoid conflicts, as you surmised, and latches on to 10.0.0.1.
You can avoid this by putting whatever sits in front of the R7800 into modem-only (bridge) mode.
And when messing around with things do remember to start things in the specified order.
As this is a router, there is probably a modem sitting in front of it. You need to get the devices to forget any inherited settings. Among other things, that means rebooting the network.
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
There's quite a lot of traffic here from people using PiHoles, so a search might be useful.
Search - NETGEAR Communities – PiHole
> [...] Got a ATT modem+router. [...]
Not a very detailed description. Maker? Model number?
> [...] When I hooked up, router picked 10.0.0.1 as the IP range,
> probably due to a conflict before I set the passthrough [...]Plausible.
> [...] but I am fine with it.
Apparently not.
> [...] I don't know why their IP addresses did not automatically
> change. [...]Only one of us was there when their addresses were assigned.
> [...] I wanted to give 10.0.0.x IP for the camera and PiHole but can't
> fine a way how.
To me, that sounds like a camera and/or Pi-hole question, not a
router question.If your (unspecified) a ATT modem+router really isn't occupying the
"192.168.1.*" subnet now, then why not configure the R7800 to use it,
and stop worrying about the camera and Pi-hole?- manjulapraAspirant
manjulapra wrote:
The ATT router is occupying 192.168. range. I am not certain how to turn that off. Do I thrun off DHCP Server?
See the attached image
Try this:
bgw320-505 bridge mode - Google Search
Not all modem/routers (or gateways) let you use modem only mode. But those search results might help.
