eric_bor's avatar
Jan 22, 2016
Is it possible to forward more than one port to a single port? (Or, how can I do this?)
Hi everyone,
I have a service running on a port (let's say 9999).  I can forward 9999 external to 9999 internal.  But, what I would like to do is to forward anything that comes in on 80 or 9999 (externally) to 9999 (internally).  Is there a way to do this with the R7000?  So far, anything I've tried has caused it to complain that the port is already in use.
Thanks in advance for any help.
  • eric_bor
    (2 or more) external ports - (1) internal port - (2 or more) IP address (this should work)
    (2 or more) external ports - (1) internal port - (single) IP address (NO!!!)
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi eric_bor,
    Correct me if I am wrong. You wanted to open one port number for a service which will be used by multiple devices. If yes, you can configure it by changing the external port to a different port number and set the same internal port number.
  • Hi James,
    Close. The problem I'm trying to overcome is that I am able to access the port for this service when on my internal network or via Internet. But, at work, behind vpn, I cannot use that port, so I would like to allow *either* port 80 or port 9999 to go to port 9999. So, via port 80, go to 9999. Via port 9999, go to 9999 as well.
    Thanks!
