MrRankDog
Nov 16, 2015Aspirant
IS YOUR ROUTER MAC ID BOUND TO YOUR INTERNET PROVIDER?
I bought my R8000 on October 23, 2014. I've owned MANY NETGEAR ROUTERS and had a cable modem here in Anchorage, Alaska for as long as I can remember. For quite some time now I've had the strangest ...
- Nov 18, 2015
I figured out the problem early this morning after hundreds of hours work, THE R8000 IS DEFECTIVE. How do I know this: The WPS Quit Working Long Ago, Wireless Connectivity Was Spotty At Best And Seemed To Change With Every Boot Up, MAC ID Problems NOBODY Seems Willing To Explain To Me, I HOOKED UP MY OLD NETGEAR 900 AND IT WORKED PERFECTLY!! TO BAD MY WARRANTY EXPIRED ON OCTOBER 23RD, 2015
Retired_Member
Nov 16, 2015All you need to do is copy the MAC ADDRESS and when changing a router enter it and check you this MAC ADDRESS.
When your account was setup up the service tech used your PC without a router and that PC's LAN card's MAC ADDRESS was entered in your ISP's system. If your mac changes the ISP will hand out a different IP
Retired_Member
Nov 16, 2015Some ISP's won't authorise a different MAC Address without contacting them. Comcast really doesn't care, rebooting their modem with a different PC or router attached will work but the Public IP will change.
