MrRankDog
Nov 16, 2015Aspirant
IS YOUR ROUTER MAC ID BOUND TO YOUR INTERNET PROVIDER?
I bought my R8000 on October 23, 2014. I've owned MANY NETGEAR ROUTERS and had a cable modem here in Anchorage, Alaska for as long as I can remember. For quite some time now I've had the strangest ...
- Nov 18, 2015
I figured out the problem early this morning after hundreds of hours work, THE R8000 IS DEFECTIVE. How do I know this: The WPS Quit Working Long Ago, Wireless Connectivity Was Spotty At Best And Seemed To Change With Every Boot Up, MAC ID Problems NOBODY Seems Willing To Explain To Me, I HOOKED UP MY OLD NETGEAR 900 AND IT WORKED PERFECTLY!! TO BAD MY WARRANTY EXPIRED ON OCTOBER 23RD, 2015
TheEther
Nov 19, 2015Guru
You don't need WPS.
netwrks
Nov 19, 2015Master
So many problems are resolved with a simple reset to factory default. Very seldom, do I not, reset a router to factory default after a firmware upgrade.
If I didn't, and issues crop up, (WAN drops, poor performance, wonky wireless, router reboots etc) that's my start point, in the remedy. That way you are starting with a clean slate, and, also ensuring the new firmware is getting loaded correctly.
