thompsondc's avatar
May 15, 2023
Login when in Access Point mode
I've set my R7800 into access point mode, as I have a Mikrotik RB4011+ performing DHCP.  I can connect to my Nighthawk via the android app, but not via IP over the LAN.  The only thing I want to do is connect to confirm it's getting firmware updates and such, but it seems silly that I can't do it over the LAN via IP.  I must be doing something wrong.
  • Your call.
    The alternative is, of course, to leave the R7800 to manage its IP address and to tell the Mikrotik router to keeps its hands off.
    Just because it used to rule the roost does not mean that it has to do that for ever.
  • FURRYe38's avatar
    What do you mean by "I can't do it over the LAN via IP? Do you mean by web browser?
    What FW is loaded?
      • FURRYe38's avatar
        How is it now working?
        Recommend manually checking for FW updates on the NG download page or here in the forums. Sometimes NG will not post new FW to the auto update servers.
  • plemans's avatar
    Are you using the IP address the Mikrotik is assigning to it?
    in AP mode, the mikrotik assigns and IP address.
    • michaelkenward's avatar
      michaelkenward
      That's the way to do it.
      There are various ways of finding the IP address. As plemans hints, you can look at the router's list of attached devices.
      Another way is to use the Netgear genie for your operating system.
      genie | Product | Support | NETGEAR
      The good thing there is that it shows a map of the network and the AP may well show up as a clickable link. A neat tool if you want to do this regularly.
      Another way to make life easy is to fic the IP address on the AP so that you can always go to that to get at the browser graphical user interface (GUI).
      • thompsondc's avatar
        thompsondc
        Tutor
        After doing a deepdive, I've figured it out.  I have a DHCP reservation for the R7800 on the Mikrotik, which I was seeing in RouterOS's DHCP Server > Leases screen; however the R7800 is picking up a different IP (of it's choosing), much higher in number (and therefore further down the page...
        Apologies for ultimately not scrolling down to locate the correct IP.  I used the correct one, and I'm good.
        Any ideas on how to force the R7800 to take the IP reserved for it?
