aetrcsom
Mar 18, 2022Follower
Looks like Nighthawk is abandoned
To all who are curious. It seems Nighthawk is an abandoned product. I loved it when I first got it but recently I tried to activate their services so I could manage my router. It seems the app is ...
Mar 19, 2022Guru - Experienced User
You didn't really give us much to go off.
1. what router do you have? (model)
2. what actual firmware version are you on?
3. you put you have an active subscription? If you do, then you need to go through support as this is the community forum where members of the public help out. With subscription services, actual support needs to fix issues.
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
