aetrcsom
Mar 18, 2022Follower
Looks like Nighthawk is abandoned
To all who are curious. It seems Nighthawk is an abandoned product. I loved it when I first got it but recently I tried to activate their services so I could manage my router. It seems the app is ...
michaelkenward
Mar 19, 2022Guru - Experienced User
Which "Nighthawk"? (There's a lot of them about.)
Which services? Again, there are several.
It seems the app is unable to connect to their servers
Which app?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
- jrbc_Mar 20, 2022Aspirant
NIGHTHAWK APP and R7000 router.
Similar problem on my side, R7000 V1.0.11.134_10.2.119 firmware, unnable to login from my Nighthawk App from a Samsung S9 (SM-G960F).
After successful login into the App (2FA), while trying to logon with admin credentials to connet the router, an error message shows up similar to "idle time has been exceeded. Try again later. reboot your device".
Phone rebooted and Nighthawk App just reinstaled. Router firmware also recently instaled.
In the past I could connect to the router from the same Android phone.
