Unfiltered1's avatar
Oct 20, 2016
Mounting An X10 R9000
My current Netgear R7000 is mounted on a livingroom wall with the mounting holes on the bottom of the router.  Can the new X10 also be mounted to a wall or does it need to sit on a shelf?
  • Hi @Unfiltered1
    Welcome to the community!
    Yes, you can mount it!
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi @Unfiltered1
    • Unfiltered1's avatar
      Unfiltered1
      Tutor
      Hello Elaine and thank you for the reply.  Couldn't tell for sure from the pictures if the antennas would move into a position to allow hanging the router on the wall.  This is my current setup.  At the moment I'm gathering parts for a new build so it may be a while before I upgrade the router but the X10 definitely looks good.
      • ElaineM's avatar
        ElaineM
        You're very welcome.
        Glad you're liking the unit!
