homefiber
Apr 08, 2026Aspirant
Need recommendations
Normally I rent the equipment from my ISP but I hate eero (which is the only option for renting) and want to get away from it because it's only controlled via apps and I don't do apps. I need som...
homefiber
Yes but they only have eero and I do not want eero. They do not offer any other options. So I have to buy my own equipment.
Apr 08, 2026Guru - Experienced User
Do they have ONT units that are only just ONTs with out any built in routers? If so, get that then get something non eero for wifi router system.
Also ask if they support user bought ONT units, if so, then find something ONT only that you can buy that they support on there network.
