Null_Sum
Jan 19, 2017Aspirant
Netgear Nighthawk R6700 periodic network disconnects
Hey all! I have a problem that I cant seem to fix, my router seems to be disconnecting every 40 -60 seconds and stays disconnected for around 10 -15 seconds, both wireless and hardline are doing the same thing, I'm currently running firmware version V1.0.1.16_10.0.30 (this has been going on for several versions now). I'm hoping all of you can help me find an answer to why it is doing this. I have looked at the router logs and there seems to be no reason why it is doing this.
Hi Null_Sum,
Please try changing the MTU size of the router.
http://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
https://kb.netgear.com/24015/How-do-I-change-the-MTU-size-on-my-Nighthawk-router
- JamesGLNETGEAR Employee Retired
Hi Null_Sum,
1. When you say disconnected, is it disconnected from the network or still connected but no internet access?
2. Check your mode as well. Connect a computer directly to the modem and make sure the connection is stable. If not, contact ISP.
3. If connection is stable from the modem, reset the router to factory default.
- Null_SumAspirantTo clarify I lose internet access, it will look normal until I try to surf then my computer's will register something is wrong and I hardlined one computer and although it doesnt happen as often it still happens I will try to restore to factory defaults but I'm not sure why that would be the problem since it's been working fine up to a couple months ago.
Hi Null_Sum,
Bypass the router. Connect a computer directly to the modem and make sure the connection is stable. If not, contact ISP.
- Null_SumAspirantOK so I reset router to factory defaults and still the same issue, I have also bypassed the router and the issue no longer happens
- Null_SumAspirant
Still need help with this, i have done all of this and its still disconnecting
Hi Null_Sum,
